Frequently asked question
Is it safe to delete the log4j files contained in the upgrade-backup folder created after a Portal for ArcGIS upgrade?
First Published: April 26, 2022
Last Published: August 5, 2025
Yes, it is safe for those files to be deleted.
When Portal for ArcGIS is upgraded, a folder named upgrade-backup is created in the arcgisportal folder:
Default location on Windows:
C:\arcgisportal\upgrade-backup
Default location on Linux:
<install path>/arcgis/portal/usr/arcgisportal/upgrade-backup
The arcgisportal folder may be in a custom location depending on the installation configuration.
This directory contains version-specific folders with backed-up contents.  From Section 2 of the Perform an upgrade of your portal deployment documentation, it is recommended to move that folder to another location to save disk space.
The upgrade-backup folder contains multiple log4j files under /update-backup/<release>/dsdata/elasticsearch_#.#.#/lib.  It is safe for those to be deleted.
Article ID: 000027585
Software:
  • Portal for ArcGIS
  • ArcGIS Enterprise
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
