Frequently asked question
Is it possible to use custom fonts in ArcGIS Online Map Viewer Classic pop-ups?
Answer
Yes, it is possible to use custom fonts in ArcGIS Online Map Viewer Classic pop-ups. By default, there are six font options available for custom attribute configuration: Arial, Courier New, Garamond, Tahoma, Times New Roman, and Verdana.
The following steps describe how to use custom fonts in ArcGIS Online Map Viewer Classic pop-ups:
  1. Log in to ArcGIS Online, and navigate to the web map.
  2. In the Contents pane, navigate to the feature layer, click the More Options ellipsis The Ellipsis icon. icon, and select Configure Pop-up.
The Configure Pop-up option in the Contents pane menu.
  1. In the Configure Pop-up pane, click the Display drop-down list, and select A custom attribute display. Click CONFIGURE.
The Configure Pop-up pane in ArcGIS Online Map Viewer Classic.
  1. In the Custom Attribute Display window, type the desired text, and click the View HTML Source icon to view the HTML codes. In this example, the default font is Tahoma.
The Custom Attribute Display window.
The HTML codes in the source.
  1. Change the default font with a desired custom font such as Brush Script MT in the source code.
The following steps may not be applicable to all custom fonts.
  1. Click the View HTML Source icon to view texts with the specified custom font, and click OK to close the window.
The new custom font is displayed in the window.
  1. In the Configure Pop-up pane, click OK to save the modifications.
The image below shows the text in the Brush Script MT font in an ArcGIS Online Map Viewer Classic pop-up.
An ArcGIS Online Map Viewer Classic pop-up with the custom font.
Article ID:000022500
Software:
  • ArcGIS Online
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
