Frequently asked question
Is it possible to order points based on a selected column in Story Map Tour?
No, it is not possible to order points based on a selected column or field in the Story Map Tour application. When building a Story Map using the Story Map Tour template, by default, the order of the points is driven by the ObjectID. The data order on the application reflects the data order from the CSV file, shapefile or feature service shared to ArcGIS Online or Portal for ArcGIS.
Use one of the following alternatives to order the points in Story Map Tour:
Order the points manually using the Organize button
  1. In the Story Map Tour application, click Organize to order the points manually.
    Click the Organize button to order the points manually
  2. In the Organize the tour dialog box, drag and drop the image to sort the points.
  3. Click Apply.
    Drag and drop the image to sort the points
Sort the points in the selected column using the Sort tool
The Sort tool sorts the selected column in ascending or descending order.
  1. In ArcMap or ArcGIS Pro, navigate to the Sort tool.
  2. In the Sort tool dialog box, set the layer to be reordered in Input Dataset.
  3. Set a name and location for Output Dataset.
  4. In Field(s), select the field containing the values that will be used to reorder the input records.
  5. Select Sort Method.
  6. Click OK.
    Example of Sort tool in ArcMap
  7. Publish the feature layer containing the sorted field as a service from ArcMap or ArcGIS Pro.
  8. Use the published feature service to create a web map and use the web map to create a Story Map Tour.
Article ID: 000020577
Software:
  • ArcGIS Online
  • Portal for ArcGIS
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
