Frequently asked question
Is it possible to only enable expansion for specific elements in ArcGIS Dashboards?
First Published: January 4, 2022
Last Published: July 7, 2026
Yes, following the June 2026 Update it is now possible to enable or disable expansion for specific dashboard elements. This feature to expand individual elements is now called, Focus Mode. In previous releases, users were only able to enable or disable expansion for the entire dashboard.
Follow the steps below to enable Focus Mode for a given element:
  1. In ArcGIS Dashboards, in the dashboard layout, click Configure on the desired widget:
  1. Within the widget's settings, navigate to the General tab.
  2. On the General tab, under Header, turn the Enable Focus mode toggle on or off as desired. In this example, the toggle button is turned on.
  3. Click Done in the bottom right corner.
  1. This individual widget can now be expanded by clicking on the three dots that are now visible within the top right corner, and then selecting Focus Mode.
A dashboard can be also be customized by moving, resizing, adding new tabs, and grouping the dashboard elements. Refer to ArcGIS Dashboards: Dashboard layout for more information.
Article ID: 000026871
Software:
  • ArcGIS Online
  • ArcGIS Dashboards
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
