Frequently asked question
Is it possible to modify the ArcGIS Online for Organization's URL?
First Published: May 5, 2016
Last Published: July 3, 2025
Yes, it is possible by modifying the short name of the organization.
Before changing your organization short name, consider the following:
The short name uniquely defines the URL to your organization; therefore, it is recommended that you carefully consider the name you want to use. There are also important considerations for changing the short name if required.
To change your organization short name, follow the steps below:
  1. In ArcGIS Online, click the Organization tab > Settings.
  2. In General, navigate to Organization defaults and edit the name in the Short name section. Refer to ArcGIS Online: Organization defaults for more information.
Image of the Short name section in Settings tab.
  1. Click Save.
Article ID: 000012002
Software:
  • ArcGIS Online
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
