Frequently asked question
Is it possible to edit a layer in a layout without modifying the source data?
First Published: June 9, 2021
Last Published: September 4, 2025
Yes, it is possible to edit a layer in a layout without modifying the source data. A layout is a set of map elements prepared on a virtual page in ArcGIS Pro for map printing. These map elements are projected on the layout by referencing data from a specified number of layers. As the layout projects the source data from a geodatabase, sourcing the layer data from other geodatabases does not modify the data.
If the objective is to only visualize the layout, making changes to the geodatabase without saving a copy of the project is possible.
Use either one of these workflows to edit a layer without modifying the source data.
Export the edited layer to another geodatabase
  1. Start ArcGIS Pro and open the feature as a layer.
  2. Right-click the layer and click Data > Export Features.
The Export Features function on the selected layer
  1. Specify the new geodatabase as the Output Location. Insert a new name into the Output Name field.
The Export Features window used to export the selected feature into a new geodatabase
  1. Click OK. A copy of the layer referencing the new geodatabase is created on the map for editing.
Create a project folder copy in Microsoft Windows Explorer
  1. Make a copy of the project folder in Microsoft Windows Explorer.
The Microsoft Windows Explorer window with a copy of the project folder
  1. Start ArcGIS Pro and sign in if necessary.
  2. Click Start without a template.
The ArcGIS Pro Start page
  1. In ArcGIS Pro, in the Catalog pane, right-click Folders and click Add Folder Connection.
The ArcGIS Pro Catalog pane to add a folder connection
  1. Navigate to the newly copied project folder and click OK.
The file folder navigation window
  1. Apply the changes to the feature layer.
The image below demonstrates a layout with the map elements from a different layer data source. The edited feature layer is reflected in the newly inserted layout with a new map frame containing the feature layer to the layout.
The layout example in ArcGIS Pro
Article ID: 000025086
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
