Frequently asked question
Is it possible to create story maps with tabs similar to Map Stories Builder in ArcGIS StoryMaps?
Last Published: January 27, 2022
It is possible to create a story map with tabs in ArcGIS StoryMaps. This article provides the workflow.
Although it is possible to create a story map with tabs in ArcGIS StoryMaps, the functionality to display the subtabs under the same tabs on the story navigation bar is not yet available.
  1. In ArcGIS StoryMaps, select the story map and enter edit mode. Click the More actions The More actions button on the story mapbutton and select Edit story.
  2. On the edit page, click the Design tab to open the Design pane.
  3. In the Design pane, under Optional story sections, toggle the Navigation option on. Close the pane.
The Design pane with the toggle button to enable the navigation links.
  1. On the main edit page, click the Add content block The Add content block icon. icon, select Text.
  2. Fill in the desired text. Highlight the text, and click the drop-down list to select Heading.
The Heading option for the story map.
  1. Repeat Steps 4 to 5 to add more story tabs. The story navigation bar containing the story tabs is added to the top of the story map.
The story map with the navigation bar for the story tab added.
Article ID: 000027129
Software:
  • ArcGIS StoryMaps
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
