Frequently asked question
Yes, it is possible to create conditional questions in Survey123 Web Designer using the Set rule function
. However, this function is limited to Single Choice, Dropdown, Likert, and Rating questions. When setting conditions, selecting a particular answer in the primary question prompts only the related conditional question.
Follow the steps below to configure conditional questions:
| Primary question | Answer choice for the primary question | Subsequent conditional question |
| What television show genre do you prefer? | Crime | Which crime show you like the most? |
| Reality television | Which reality television show you like the most? | |
| Comedy | Which comedy show you like the most? |
The image below shows the primary and conditional questions created in Survey123 Web Designer.
Selecting a particular answer in the primary question prompts only the related conditional question.
Article ID: 000022942
Get help from ArcGIS experts
Start chatting now
