Frequently asked question
Is it possible to create a workgroup geodatabase in ArcGIS Pro?
In some instances, an organization uses a workgroup geodatabase to create multiple maps and layouts in a single project. The maps and layouts may be edited simultaneously by organization members in ArcGIS Pro. However, it is not possible to create a workgroup geodatabase in ArcGIS Pro because the SQL Server Express instance is not available.
As a workaround, create the workgroup geodatabase in ArcMap and connect it to ArcGIS Pro. Connect the workgroup geodatabase to ArcGIS Pro using the ArcSDE connection file from ArcMap, or by creating a new direct database connection to the SQL Server Express instance. Follow the instructions described below:
  1. Create a workgroup geodatabase in ArcMap. For more detailed steps, refer to ArcMap Web Help: Create a desktop or workgroup geodatabase.
  2. Connect the workgroup geodatabase created in ArcMap to ArcGIS Pro by selecting one of the options below:
Database Connection dialog box
Article ID: 000018326
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
