Frequently asked question
Is it possible to choose one window template for each screen device view in ArcGIS Experience Builder?
First Published: April 2, 2024
Last Published: April 2, 2024
No, it is not possible to choose one window template for each screen device (large, medium, or small) view in ArcGIS Experience Builder. Only one window template can be selected, but using only one template disrupts content visibility that may be affected by the screen size differences.
As a workaround, resize and rearrange the layout of a window to fit each screen device, causing every device to have a different layout for the same window. Follow the steps below to resize and rearrange the window layout for medium and small screen devices.
  1. Open the ArcGIS Experience Builder experience and click Page The Page button to open the Page panel.
  2. Click the Window tab, and select the window to be customized.
  3. On the builder toolbar, click the Edit your page for medium screen devices button to refine the layout for medium screen devices.
The 'Edit your page for medium screen devices' button
Clicking the Edit your page for medium screen devices or Edit your page for small screen devices button displays the window view in the medium-screen devices mode. The option to set the layout to Custom is in this view mode.
  1. Click the Custom button next to the window layout.
The Custom button
  1. When the Are you sure you want to enable it? dialog box is prompted, click OK.
The 'Are you sure you want to enable it?' dialog box
  1. On the window, drag the edges of a widget to resize the widget, or drag and drop a widget to a suitable position to rearrange the widget position.
  2. Repeat Step 6 to resize and rearrange the widget position for all the other widgets in the window.
  3. On the builder toolbar, click the Edit your page for small screen devices button to refine the layout for small screen devices.
The 'Edit your page for small screen devices' button
  1. Repeat Steps 4 through 7 to resize and rearrange the widgets in small-screen size mode.
  2. Click Save The Save button to save the experience.
The images below show the window views for the large, medium, and small screen devices.
The large-screen devices window view
The medium-screen devices window view
The small-screen devices window view
Article ID: 000032229
Software:
  • ArcGIS Experience Builder
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
