Frequently asked question
Is it possible to change the default tab display for the ArcMap table of contents?
Answer
Yes. At the ArcGIS 8.1.2 release, the Selection tab was added as an additional table of contents display feature. This tab must be added manually when a new document is opened. The tabs you wish to display cannot be changed within the default settings of the application. If you wish to change the tabs that are displayed in your table of contents, you must do so with each particular map document. The default ArcMap behavior cannot be modified to modify the table of contents tabs.
Article ID:000005450
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
