Frequently asked question
Is it possible to change the data source of a corrupt web map layer in ArcGIS Online?
Yes, it is possible to change the data source of a corrupt web map layer in ArcGIS Online. If a web map contains a corrupt web map layer, the layers do not appear when opening the web map in map viewer. This complicates any attempts to remove or edit the corrupt layer. In this case, ArcGIS Online Assistant can be used to update the URLs of the corrupt web map layer. To do so:
  1. Open ArcGIS Online Assistant.
  2. Log in with the ArcGIS Online account containing the corrupted web layer. All ArcGIS Online folders are listed on the left panel.
  3. Expand the folder containing the web map with the corrupted layer.
  4. Click the I want to… drop-down list on the top right corner.
  5. Select Update the URLs of Services in a Web Map.
    Image of the context menu
  6. Select the web map with the corrupted layer. The name and data source of all the layers on the web map are displayed on the right panel.
  7. Update the corrupted map layer with the correct URL, and click Update.
    Image of the update layer pane
  8. Log out of ArcGIS Online Assistant.
Note: ArcGIS Online Assistant is an unsupported product. Exercise caution when using this tool and test workflows before using it in production.
Article ID: 000018888
Software:
  • ArcGIS Online
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
