Frequently asked question
Is it possible to change field order in an attribute table?
Answer
It is not possible to change field display order for a table permanently within ArcGIS. Changes made in regards to field order can be saved within a particular Map Document. This behavior is common across the various supported data types.
When a new field is added to a table in ArcGIS, the field will be appended to the last field on the right hand side of the table.
Article ID:000004981
Software:
  • ArcMap
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
