Frequently asked question
Is it possible to apply different symbology in multiple layouts for the same map in ArcGIS Pro?
Last Published: June 29, 2021
No, it is not possible to apply different symbology in different layouts referencing the same map. The modifications made in the map are reflected in all the map frames in different layouts. As a workaround, make a copy of the map, add it to the desired layout, and edit the symbology of the map feature layer. Complete the steps below to do so:
  1. Open the ArcGIS Pro project.
  2. In the Catalog pane, click Project and expand the Maps folder. Right-click the original map, and click Copy.
Copying the map in the Maps folder in the Catalog pane.
  1. Right-click the Maps folder, and click Paste.
Pasting the map in the Maps folder in the Catalog pane.
  1. Click the desired Layout view tab to activate the Layout view. The tab turns blue when it is activated.
  2. On the top ribbon, click the Insert tab, and click Map Frame. In the Map Frame drop-down menu, select the copied map in Step 3. In this example, the copied map is labelled as Map 1.
Selecting the copied map in the Map Frame drop-down menu from the Insert tab.
  1. Modify the symbology of the map feature layer. Refer to ArcGIS Pro: Apply symbols to feature layers for steps to do so.
  2. Repeat steps 2 through 6 for all desired layouts.
Article ID: 000025916
Software:
  • ArcGIS Pro 2 8 x
  • ArcGIS Pro 2 7 x
  • ArcGIS Pro 2 x
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
