Frequently asked question
Is it necessary to compress if all objects are registered as versioned with the option to move edits to base?
Answer
Yes, it is still required to periodically execute the compress command in ArcGIS to remove non-referenced states of the geodatabase, even when all the objects are registered with the option to move edits to base.
When editing a class registered as versioned with the option to move edits to base, edit operations still generate states within the geodatabase for maintaining the delta changes for the edit operation. When the edit session is saved, the changes are then moved from the delta tables to the base tables, and the state no longer contains any modified versioned tables. But, the state and the states lineage remain in the geodatabase. Over time, based on the volume of editing occurring, the number of states and entries in the state lineages table can lead to performance degradation in the application; therefore, it is recommended to still periodically execute the compress command to delete states and their corresponding lineage entries.
Article ID:000010803
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
