Frequently asked question
How does ArcView geocoding compute composite weights?
Answer
A composite weight is the sum of the individual weights for all field
comparisons for each record pair.
If a field agrees, the agreement weight (log to the base 2 of the ratio of the "m" and "u" probabilities) is used.
If a field disagrees, a disagreement weight is computed as log to the base 2 of the ratio of 1-m and 1-u. The result is a negative weight.
Therefore, agreements add to the composite weight, and disagreements subtract from the composite weight. The composite weight indicates that the higher the score, the greater the agreement.
Article ID:000006269
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
