Frequently asked question
How do I download ArcGIS Field Maps (Android) without access to Google Play?
First Published: October 27, 2020
Last Published: September 23, 2025
If you don’t have access to Google Play, and it is necessary to download the latest version of ArcGIS Field Maps to an Android device, Esri provides a setup that can be downloaded and installed on the device.
While downloading ArcGIS Field Maps from Google Play is the recommended method, it is also possible to download Field Maps from Esri to a workstation and install it on the device.
  1. Download the setup file for Android
  2. Run the .exe file, and extract the contents to your machine.
  3. Use the extracted files and your organization’s deployment system to deploy the app to your devices.
Article ID: 000024486
Software:
  • ArcGIS Field Maps Android
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
