Frequently asked question
How are toolbar settings maintained?
Answer
Standard toolbar settings are maintained within the default template (Normal.mxt) only.
Custom toolbar settings are maintained within the default template, or the current map document (.mxd). When saved within a map document (.mxd) custom toolbars are maintained solely within that document. The settings are maintained if the document is copied to another machine, or opened by another user, and even when they toolbar itself is turned off, but they will not appear in any other documents.
ArcGIS 9.0 and 9.0 Sp1 maintain custom toolbars only when they are turned on within the document (.mxd).
Article ID:000007183
Software:
  • ArcMap 9 x
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
