Frequently asked question
Does the ArcMap Server support documents using SDE Direct connect?
Answer
Yes, you will be able to serve ArcMap documents that use SDE Direct connect. You have to set the SDEHOME environmental variable of the server machine so that it points to <ArcIMS install directory>/server directory to be able to serve the map document.
Article ID:000005165
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
