Frequently asked question
Does the ArcGIS Enterprise portal support joins and relates?
First Published: March 9, 2023
Last Published: April 8, 2026
Yes, the ArcGIS Enterprise portal supports joins and relates. To join features, use the Join Features analysis tool in Map Viewer, which creates a new layer with appended attributes based on a shared field or spatial relationship. Refer to Portal for ArcGIS: Join Features for more information.
Follow the steps below to use the Join Features tool:
  1. Log in to the ArcGIS Enterprise portal.
  2. Open the web map in Map Viewer.
  3. Click the Analysis tab.
  4. In the Analysis pane, click Tools and select Join Features under Summarize data.
The Join Features tool under the Summarize Data node
In contrast, layers with related records show linked columns on the right side of the attribute table and open the related records in a separate table view. In this example, the Status_Polygon column displays the related records. Refer to Portal for ArcGIS: View related records for more information.
The related record column
Article ID: 000029450
Software:
  • Portal for ArcGIS
  • ArcGIS Enterprise
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
