Frequently asked question
Does Maplex for ArcGIS have a page size limit?
Answer
The ESRI Maplex Label Engine was designed to place labels on printed map sheets and is optimized to produce the best quality of placement on a map extent that does not exceed the size of an A0 sheet (841 mm X 1,189 mm). To place labels for a larger extent, it is necessary to divide the total extent into tiles and place the labels for each tile separately. As a guideline, verify that the tile size does not exceed the size of an A0 (or ANSI E
size) sheet in page units. For map extents larger than A0, the placement quality may degrade and, in some cases, labels may not be produced by the placement engine.
Article ID:000006771
Software:
  • ArcMap 9 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
