Frequently asked question
Does GET_SERVICE_INFO on an ArcMap Service return a projection ID?
Answer
For ArcIMS version 9.1 (and newer versions), a GET_SERVICE_INFO request on an ArcMap Service returns both the projection string and id, unless the projection string has been modified in the map document. In that case, only the projection string is returned.
In prior versions, only the projection string is returned in response.
Article ID:000006844
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
