Frequently asked question
Does ArcMap Server support OLE DB or ODBC data connections?
Answer
ArcMap Server, at ArcIMS version 4.0.1 and after, supports layers that contain table joins where the table is accessed through ArcGIS supported OLE DB or ODBC connections.
Standalone tables (those present in the ArcMap document, but not joined to a feature class layer) are not supported. They will be dropped from the map when served.
OLE DB is not supported in ArcIMS 4.0
Article ID:000005838
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
