Frequently asked question
Can the sketch feature title in Map Viewer be used as labels in ArcGIS Online and ArcGIS Enterprise portal?
First Published: February 6, 2025
Last Published: February 6, 2025
No, sketch feature titles cannot be used as labels on a web map to annotate sketch features in ArcGIS Online and ArcGIS Enterprise portal. This is a known limitation for sketch layers, which are primarily used as manually drawn, temporary annotations. In cases where sketch features are used to highlight specific elements on the web map, adding annotations is an effective alternative to enhance visualization. This preserves the labeling properties of the underlying feature layers while simultaneously enhancing map interactivity.
The image below shows the Sketch pane with the sketch feature title under the 'Feature name' parameter in Map Viewer.
The Sketch pane in Map Viewer
As a workaround, use text sketch features to annotate the existing sketch features on the web map in ArcGIS Online and ArcGIS Enterprise portal.
  1. Open the web map with the sketch features in ArcGIS Online or ArcGIS Enterprise portal.
  2. In Map Viewer, click Add on the Contents toolbar and select Create sketch layer to create a new sketch layer.
  3. Add annotations to the existing sketch features using the Text sketch tool. Refer to ArcGIS Online: Add text or ArcGIS Enterprise: Add Text for instructions.
The web map below shows the text sketch layer used to annotate the underlying polygon sketch features in Map Viewer.
The map view in Map Viewer
Article ID: 000034504
Software:
  • ArcGIS Online
  • Portal for ArcGIS
  • ArcGIS Enterprise
Get support with AI
Start chatting now
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
