Frequently asked question
No, the Recalculate button cannot be removed from a survey question in the ArcGIS Survey123 field app. The button becomes available when there is an expression defined in the calculation column, allowing the output to update based on the current input data. However, in some instances, the button may cause unintended changes when editing the survey response. The survey below shows the Recalculate button in the Editing pane.
To prevent accidental taps that lead to unintended changes, there are two workarounds to hide the Recalculate button from the survey.
Note: This workflow only applies to survey questions with expressions that consistently return the same result.
The survey below shows the Editing pane without the Recalculate button.
Note: Optionally, hide the question to restrict access for editing the response via the ArcGIS Survey123 web app using the hide parameter to ensure the initial survey responses remain unchanged. Refer to Esri Community: Hiding questions and survey elements (hide) for more information.
Article ID: 000035845
Get help from ArcGIS experts
Start chatting now
