Frequently asked question
Can the automatically created Validation Status field be removed when running a batch attribute rule in ArcGIS Pro?
First Published: October 24, 2023
Last Published: March 6, 2026
No, it is not possible to remove the Validation Status field from an attribute table when running a batch attribute rule in ArcGIS Pro.
As a workaround, to remove the Validation Status field, export the feature class and remove the Validation Status field from the new feature class containing the original feature class attributes.
  1. Create a new file geodatabase to store a new feature class. Refer to ArcGIS Pro: Use the Catalog pane in ArcGIS Pro for instructions.
A new file geodatabase is useful to store the feature class without the Validation Status field while retaining the field for the feature class stored in the original geodatabase.
  1. Navigate to the Analysis tab and click Tools. The Geoprocessing pane opens.
  2. In the Geoprocessing pane, search for and select the Export Features tool.
Alternatively, the Feature Class To Feature Class tool can be used for this workaround.
  1. In the Export Features pane, configure the parameters of the tool.
    1. For Input Features, click the drop-down menu and select the feature class with the Validation Status field. In this example, the feature class named County is selected.
    2. For Output Feature Class, click Browse The Browse icon. Browse to the newly created file geodatabase in Step 1 and select it to store the output feature class.
    3. Scroll down, and click Fields to expand the list of the fields in the feature class.
    4. Under Field Map, browse and select the VALIDATIONSTATUS field. Click the Remove The Remove icon icon displayed beside the VALIDATIONSTATUS field.
    5. Leave all the other parameters as default. Click OK.
The Export Features pane.
Article ID: 000031336
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
