Frequently asked question
No, it is not possible to manually create progress lines to connect points using the guided map tour template in ArcGIS StoryMaps. As a workaround, use a Sidecar template to manually create the progress lines in an express map. In an express map, drawing tools are consolidated on the header of the map designer. This helps in creating cartographic features such as points, lines, and areas on a map that replicate a guided map tour template.
.Note: Press Shift and click Add numbered points to add multiple points at once to the express map.
> Duplicate.
and select Slow Fade.
.Note: Adjust the zoom level accordingly on the express map to display two numbered points clearly.
> Duplicate.
Note: Repeat Steps 18 through 20 until all the numbered points in the express map are connected with the arrowed line.
The published express map below shows all the connected numbered points, replicating a guided tour template using the Sidecar template.
Article ID: 000032601
Get help from ArcGIS experts
Start chatting now
