Frequently asked question
No, it is not possible to remove a point marker from a geopoint question in ArcGIS Survey123. By default, in a survey form, the geopoint question displays a blue point marker symbol on the map. In some instances, the point marker overlaps with other map elements. The map below shows the point marker overlapping with an administrative boundary line.
symbol=<filename>?scale=0
The following is an example of the expression.
symbol=icon.png?scale=0
The map below shows the symbology for the geopoint question is hidden.
Article ID: 000041891
Get help from ArcGIS experts
Start chatting now
