Frequently asked question
Can image attachments be viewed directly in the ArcGIS Dashboards table element?
First Published: July 28, 2026
Last Published: July 28, 2026
No, image attachments cannot be viewed directly in the table element in ArcGIS Dashboards. The table element is limited to displaying attribute fields and does not render or embed attachment content within the grid.
As an alternative, use one of the workflows provided below to enhance attachment accessibility in a dashboard.
Display attachments in pop-ups
  1. In Map Viewer, configure the web map’s pop-up to display attachments. Refer to ArcGIS Online: Add attachments for instructions.
  2. In ArcGIS Dashboards, create a dashboard and add a map element. Refer to ArcGIS Dashboards: Create a dashboard for instructions.
  3. Add a table element to the dashboard. In the Select a layer window, select the feature layer from the map.
  4. In the Table window, on the Data tab, set the following configurations under Data options:
    1. For Table type, select Features.
    2. For Value fields, click Add field and select the fields from the drop-down list.
  5. In the Table window, on the Actions tab, under When selection changes, click Show pop-up to expand the action section and toggle the map element on. Configure other actions, if necessary.
  6. Click Done. Click Save The Save icon > Save on the dashboard’s toolbar.
The dashboard below displays attachment in the pop-up when a feature is selected in the table element.
The attachment displayed in the pop-up
Use the details element in the dashboard
Use the details element with the Attachments option enabled in Dashboards. The details element displays attachments for selected features but cannot render attachments directly within the table element. Refer to ArcGIS Dashboards: Details for more information.
The dashboard below displays the attachment in the details element.
The attachments displayed in the details element
Use the Table widget in ArcGIS Experience Builder and embed it in Dashboards
  1. Create a web experience and add a Map widget in Experience Builder. Refer to ArcGIS Experience Builder: Create your first web experience for instructions.
  2. On the Insert widget panel, on the New tab, under Data centric, drag and drop the Table widget onto the canvas.
  3. In the configuration panel, on the Content tab, configure the following settings:
    1. Under Mode, select Interact with a Map widget.
    2. Click the drop-down arrow and select the map under Current page.
    3. Under Options, click Column to expand the section and toggle Show attachments on.
The configurations set on the Content tab
  1. Save, preview, and publish the experience.
  2. On the builder toolbar, click More options The More options icon and select Copy published item link.
The Copy published item link option
  1. In Dashboards, create a dashboard and add an embedded content element. Refer to ArcGIS Dashboards: Create a dashboard for instructions.
  2. In the Embedded content window, on the Data tab, set the following configurations under Data options:
    1. Under Settings, select Static for Type.
    2. For Content Type, select Document.
    3. For URL, paste the published web experience’s link in the text box.
  1. Click Done. Click Save The Save icon > Save on the dashboard’s toolbar.
The dashboard below displays attachments in the Table widget within the embedded experience.
The attachments displayed in the Table widget
Article ID: 000042522
Software:
  • ArcGIS Online
  • ArcGIS Experience Builder
  • ArcGIS Dashboards
Get support with AI
Start chatting now
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
