Frequently asked question
Can I use the ESRI OLE DB provider to connect to a Microsoft Access.mdb file that is not a geodatabase?
Answer
No you cannot. If you do use the ESRI OLE DB provider to connect to a non-geodatabase Access.mdb, the ADO/OLE DB connection will return the following error:
Error number : -2147220973
Error description: "Underlying DBMS error".
Use one of the Microsoft Jet OLE DB providers to make the connection.
Article ID:000005699
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
