Frequently asked question
Can I edit annotation in an 8.0.2 geodatabase with ArcGIS 8.1?
Answer
Some edits will not be allowed. If you are editing an existing 8.0.2 version geodatabase with ArcGIS 8.1, you will be prevented from making edits to annotation that would cause it to become incompatible with ArcInfo 8.0.2. If you want to edit your geodatabase annotation with ArcGIS 8.1, if the geodatabase was created with ArcInfo 8.0.2, you should upgrade it to 8.1.
For more information on how to upgrade your geodatabase, see ArcGIS online documentation under 'Working with geodatabases.'
Article ID:000003934
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
