Frequently asked question
Can I automatically connect to the ArcWeb Toolbar 1.0 when opening ArcMap?
Answer
Yes. You can automatically connect to ArcWeb Services each time you open ArcMap by setting to true the RECONNECT_AT_ARCMAP_START value in your login.xml file. To change this value, open your login.xml file in a text editor and set the RECONNECT_AT_ARCMAP_START value to True.
<RECONNECT_AT_ARCMAP_START>True</RECONNECT_AT_ARCMAP_START>
Article ID:000006328
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
