Frequently asked question
Can geometric network datasets be published to the ArcGIS Enterprise portal from ArcGIS Pro?
First Published: June 20, 2024
Last Published: September 29, 2026
No, it is not possible to publish geometric network datasets to the ArcGIS Enterprise portal from ArcGIS Pro, and this is expected behavior. Geometric network datasets can be published to the ArcGIS Enterprise portal only in ArcMap. Recent ArcGIS Pro tool updates include the utilization of a trace network instead of geometric. Refer to ArcGIS Pro: Tools that are not available in ArcGIS Pro for additional information regarding tools no longer supported in ArcGIS Pro. ArcGIS Pro can read and view geometric network datasets but cannot edit or publish them.
Alternatively, publish the geometric dataset as a trace network dataset or geoprocessing service to the ArcGIS Enterprise portal.
Publish the geometric network dataset as a trace network dataset
  1. Convert the geometric network dataset to a trace network dataset using the Convert Geometric Network To Trace Network (Trace Network) tool. Refer to ArcGIS Pro: Supported geodatabases for instructions.
  2. Publish the trace network dataset. Refer to ArcGIS Pro: Publish the trace network as a feature service for information.
Publish the geometric network dataset as a geoprocessing service
  1. Save the geometric network dataset as a service definition (.sd) file. Refer to ArcGIS Pro: Save a connected service definition for instructions.
  2. Publish the .sd file to the ArcGIS Enterprise portal. Refer to ArcGIS Pro: Publish a service definition for information.
Article ID: 000032823
Software:
  • ArcGIS Pro
  • Portal for ArcGIS
  • ArcGIS Enterprise
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
