Frequently asked question
Can geocoding return lines or polygons in ArcGIS Pro?
First Published: March 9, 2026
Last Published: July 3, 2026
No, it is not possible to obtain geocoding output other than point features. In ArcGIS Pro, geocoding outputs are always point features, even when a locator role uses lines or polygons as reference data. The map below shows the geocoding output from a locator role that uses a line feature class as the primary reference data. The output is displayed as red point features.
The geocoding output as red point features
As a workaround, to retain the original geometry after geocoding, use a unique identifier as the common field to join the geocoded output back to the reference layer.
  1. Open the project containing the primary reference data in ArcGIS Pro.
  2. In the Contents pane, right-click the reference layer and select Attribute Table. In this example, the reference layer is named 'streets'.
  3. Add a unique identifier field as a new field to the table. In this example, Field Name is specified as UNIQUEID, and Data Type is specified as Long.
The Fields view with a new unique identifier field added
  1. On the Fields tab, in the Manage Edits group, click Save.
  2. Click Close to close the Fields view.
  3. In the reference layer’s table, populate the unique identifier field with unique values. In this example, a six-digit unique number is specified for each feature.
The attribute table includes a unique identifier field with a six-digit value
  1. On the Edit tab, in the Manage Edits group, click Save.
  2. Click Close to close the attribute table.
  3. Create a locator using the Street Address role. Refer to ArcGIS Pro: Create a Street Address locator for instructions.
  4. Add the unique identifier fields from the reference data as custom output fields to ensure unique identifiers are returned with all geocoding results. Refer to ArcGIS Pro: Add a custom output field to your locator for instructions. In this example, UNIQUEID is specified in Custom Output Fields and in the Field Mapping parameter for both UNIQUEID_left and UNIQUEID_right.
The parameters in the Create Locator pane
  1. Click Run.
  2. Click the Analysis tab. In the Geoprocessing group, click Tools.
  3. In the Geoprocessing pane, search for and click Geocode Addresses (Geocoding Tools). Run the tool using an input table containing address information from the reference data and the newly created locator.
The geocoded output table with a unique identifier field
  1. Click the Analysis tab. In the Geoprocessing group, click Tools.
  2. In the Geoprocessing pane, search for and click Join Field (Data Management Tools). Run the tool to join the geocoded output table to the reference layer using the unique identifier field.
The Join Field pane
The attribute table of the reference layer shows a successful join with the geocoded output table, and the map displays the original line geometry.
The attribute table shows a successful join, and the map displays the original line feature geometry
Article ID: 000040708
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
