Frequently asked question
Can descriptive text be added to the Edit tool in the ArcGIS Instant Apps Sidebar template?
First Published: September 23, 2025
Last Published: September 23, 2025
No. The Edit tool in the ArcGIS Instant Apps Sidebar template does not provide an option to add or display custom descriptive text in the side panel. The tool is designed specifically for editing feature geometry and attribute in the configured layers, and there is no direct way to add descriptive text. Adding descriptive text is useful for providing editing guidance and helping users avoid errors when updating features.
Alternatively, the descriptive text can be added by configuring forms in ArcGIS Online Map Viewer. Refer to the following steps for instructions.
  1. Log in to ArcGIS Online.
  2. Click Content > My content.
  3. On the My content tab, navigate to the web map.
  4. Click the More Options button The More Options icon and select Open in Map Viewer.
The Open in Map Viewer option
  1. In Map Viewer, navigate to the Contents (dark) toolbar, and click Layers The Layers icon and select the editable layer.
  2. On the Settings (light) toolbar, click Configure editing > Forms The Configure editing and Forms icon .
  3. In the Configure form window, add the descriptive text using the Info element from the Form elements list. Refer to ArcGIS Online: Add descriptive text for instructions.
  4. Click OK to close the Configure form window and save the form to the layer.
The Configure form window
  1. On the Contents (dark) toolbar, click Save and open > Save.
The image below shows the descriptive text is added to the Edit tool when using the same web map in the ArcGIS Instant Apps Sidebar template .
The descriptive text is added to the Edit tool in the ArcGIS Instant Apps Sidebar panel
Article ID: 000037842
Software:
  • ArcGIS Online
  • Configurable Web Apps
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
