Frequently asked question
Can dashboards be printed from ArcGIS Dashboards?
Last Published: December 13, 2024
No, it is not possible to print a dashboard directly from ArcGIS Dashboards, as there is no built-in feature for direct printing from the web app. To work around this, the dashboard can be printed using two other web apps available in ArcGIS Online, that is, ArcGIS Experience Builder and ArcGIS Insights, or using the browser's print feature.
Using ArcGIS Experience Builder
In ArcGIS Experience Builder, adding a Button widget to an Embed widget containing a dashboard link provides a convenient print option for dashboard views. Refer to Esri Canada: Printing from ArcGIS Dashboards? Let me show you how to do it for instructions. This method allows the user to capture and print specific views of the dashboard.
Using ArcGIS Insights
This workflow requires the ArcGIS Insights license. Refer to ArcGIS Insights: ArcGIS Administration of Insights in ArcGIS Enterprise and Insights in ArcGIS Online for more information.
In ArcGIS Insights, create a workbook with the same data as the dashboard and print the data. Refer to ArcGIS Insights: Create a workbook and ArcGIS Insights: Print a report for instructions.
Esri recommends organizing the workbook content so the card dimensions fit the preferred printing layout, ensuring an accurate display of elements in the printed output.
Using the browser's print feature
Open the dashboard in ArcGIS Dashboards and use the browser’s built-in feature to print the dashboard. However, note that the print feature may have limitations and certain elements of the dashboard may be excluded due to the size of the print display.
Optionally, a data-driven element from the dashboard can be printed from a local machine by downloading it as a CSV file to the local drive.
Refer to the following browsers' documentation for instructions to print using their print feature.
    Several attempts to specify an appropriate paper size may be necessary to ensure all the elements from the dashboard are included in the browser's print preview.
    Article ID: 000034126
    Software:
    • ArcGIS Online
    • ArcGIS Insights
    • ArcGIS Experience Builder
    • ArcGIS Dashboards
    Get support with AI
    Start chatting now
    Related Information
    Discover more on this topic
    Get help from ArcGIS experts
    Contact technical support
    Start chatting now
    Go to download options
