Frequently asked question
No, clauses in the SQL Expression Builder cannot be reordered after they are added in ArcGIS Experience Builder. In some instances, clauses can contain relationships that depend on preceding clauses, and changing their order can alter the intended logic or produce unexpected results. Refer to Problem: The Query widget in ArcGIS Experience Builder returns incorrect results when using multiple filter clauses for more information. While individual clauses cannot be reordered, the Filter and Query widgets allow entire filters or queries to be reordered by dragging them in the configuration panel of the respective widget. As a workaround, delete and recreate the clauses or duplicate and modify them in the preferred order to achieve the desired clause order in the SQL Expression Builder.
In the SQL Expression Builder window of the web experience, click Duplicate
on the original clauses or clause sets in the preferred order and modify the duplicated clauses as required before deleting the original clauses. Refer to ArcGIS Experience Builder: SQL Expression Builder for more information.
In the SQL Expression Builder window of the web experience, click Delete clause
or Delete clause set
to remove the existing clauses or clause sets before clicking Add clause or Add clause set to recreate them in the preferred order. Refer to ArcGIS Experience Builder: SQL Expression Builder for more information.
Article ID: 000043335
Get help from ArcGIS experts
Start chatting now
