Frequently asked question
No, it is not possible to create buffers around point features when collecting data using the ArcGIS Field Maps mobile app. ArcGIS Field Maps currently does not offer the capability to create buffers or lines surrounding the collected point features in real time. Alternatively, buffers can be created around the point features after the data is collected in ArcGIS Field Maps Designer. Follow the following workaround to create a buffer around the point features.
The image below shows the buffers created around the point features in ArcGIS Field Maps Designer.
Buffers can also be created around the point features after the data is collected in ArcGIS Online Map Viewer. Refer to ArcGIS Online: Create Buffers (Map Viewer) for more information.
Another option is to collect the data points around the desired location of the point feature at a distance to emulate a buffer. However, this task may be time-consuming if the point features are collected at a larger distance. This is shown in the image below as an example.
Article ID: 000032407
Get help from ArcGIS experts
Start chatting now
