Frequently asked question
Can a transformation between a sphere or spheroid and a datum be performed?
Answer
No geographic (datum) transformation parameters have been calculated to transform data from a datum to a sphere, or from a sphere to a datum. No geographic transformation can be performed between a datum and a sphere.
A datum is defined on an oblate spheroid, which is a flattened oval shape, with a larger radius in the horizontal (equatorial) plane than the vertical (polar) plane. The radius of the spheroid changes continuously from the greatest length at the equator as the radius is measured from the equator to the poles.
Oblate spheroid
[O-Image]
The radius of a sphere has the same measurement in every direction.
Because the curve defining the spheroid changes continuously, while the curvature of the sphere is always the same, no geographic (datum) transformation can be calculated that will accurately perform a transformation between the two surfaces.
Article ID:000009008
Software:
  • ArcMap
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
