Frequently asked question
Can a shapefile have only a single point?
First Published: September 12, 2022
Last Published: August 6, 2025
No, you cannot use a shapefile that has only a single point.
The extent of a feature dataset or feature class in a geodatabase is defined by the allowed extent of the coordinate system assigned to the data. In a shapefile, the extent is defined by the extent of the features in the file - points, lines, polygons, or multipatch. Since a single point does not have an extent, a shapefile that only contains one point may not display, or may cause other issues in the software. This is not a bug in the software. This is a limitation of the geometry display in a shapefile data model.
Article ID: 000028377
Software:
  • ArcMap
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
