Frequently asked question
Can a multipatch feature be directly converted to a line feature in ArcGIS Pro?
First Published: June 18, 2026
Last Published: June 18, 2026
No, a multipatch feature cannot be directly converted into a line feature in ArcGIS Pro. The feature, which is derived from a 3D model, must first be converted into a 2D polygon footprint using the Multipatch Footprint tool. The polygon footprint is then converted into a line feature using the Polygon To Line or Feature To Line tool, and the workflow is provided below. Converting it to a line feature makes the resulting boundary edges available for network analysis, topology validation, and other workflows that require a linear geometry representation.
  1. Create a 2D polygon footprint from the multipatch feature using the Multipatch Footprint geoprocessing tool. Refer to the first workflow in How To: Convert 3D features to 2D in ArcGIS Pro for instructions.
The polygon footprint is displayed on the map.
The polygon footprint displayed on the map
  1. Insert a new map.
  2. Add the polygon footprint created in Step 1 to the new map.
    1. In the Catalog pane, click the Project tab and navigate to the geodatabase of the project.
    2. Right-click the newly created polygon footprint and select Add To Current Map.
  3. Convert the polygon footprint into a line feature.
    • Use the Polygon To Line geoprocessing tool if one line per shared boundary segment and the LEFT_FID and RIGHT_FID fields (polygon IDs on each side) are required. However, it does not preserve input polygon attributes in the output.
    • Use the Feature To Line geoprocessing tool if preserving the attributes is required by checking the Preserve attributes parameter.
The line features are displayed on the map.
The line features displayed on the map
Article ID: 000041858
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
