Answer
** Internal Publish Only! This article may contain information that is not intended for external circulation. **
Yes, as follows:
AuthorizeASR
Authorizes an ASR from a given string.
Syntax
HRESULT AuthorizeASR(BSTR strAsr, BSTR password)
Parameters
The AuthorizeASR function uses the following parameters:
Parameter Description strAsr ASR string. password Password string.
Return Values
The following values are returned by AuthorizeASR:
Return Value Description HRESULT S_OK if success, E_FAIL if error.
Error Returns
If HRESULT is equal to E_FAIL, run get_LastError to view a description of the error.
Possible error codes and messages for AuthorizeASR: · -1: “Could not process ASR” · -2: “ArcGIS Licensing handle error” · -3: “Invalid Password” · -4: “ASR is invalid or corrupt” · -98: “Could not load AfCore.dll”
AuthorizeASRFromFile
Authorizes an ASR from a file.
Syntax
HRESULT AuthorizeASRFromFile(BSTR fileName, BSTR password)
Parameters
The AuthorizeASRFromFile function uses the following parameters:
Parameter Description fileName ASR file path. password Password string.
Return Values
The following values are returned by AuthorizeASRFromFile:
Error Returns
Possible error codes and messages for AuthorizeASRFromFile: · -1: “Could not process ASR” · -2: “ArcGIS Licensing handle error” · -3: “Invalid Password” · -4: “ASR is invalid or corrupt” · -98: “Could not load AfCore.dll”
DeauthorizeASR
Deauthorizes an ASR from a given string.
Syntax
HRESULT DeauthorizeASR(BSTR strAsr, BSTR password)
Parameters
The DeauthorizeASR function uses the following parameters:
Return Values
The following values are returned by DeauthorizeASR:
Error Returns
Possible error codes and messages for DeauthorizeASR: · -1: “Could not process ASR” · -2: “ArcGIS Licensing handle error” · -3: “Invalid Password” · -4: “ASR is invalid or corrupt” · -98: “Could not load AfCore.dll”
DeauthorizeASRFromFile
Deauthorizes an ASR from a file.
Syntax
HRESULT DeauthorizeASRFromFile(BSTR fileName, BSTR password)
Parameters
The DeauthorizeASRFromFile function uses the following parameters:
Return Values
The following values are returned by DeauthorizeASRFromFile:
Error Returns
Possible error codes and messages for DeauthorizeASRFromFile: · -1: “Could not process ASR” · -2: “ArcGIS Licensing handle error” · -3: “Invalid Password” · -4: “ASR is invalid or corrupt” · -98: “Could not load AfCore.dll”
