Frequently asked question
Are there any limitations when using the ActiveX Connector with ArcMap Server?
Answer
The ActiveX Connector was not designed to work with ArcMap Server.
The ActiveX Connector API can be used with an ArcMap service to
· generate a basic map
· change layer visibility
· zoom in and out
· pan
· filter a recordset or layer.
In addition, the following tasks can be accomplished by sending raw ArcXML using the ArcIMSConnector.SendAxlRequest() method:
· adding an acetate layer
· buffering.
Due to limitations of ArcMap Server, the ActiveX Connector cannot be used with an ArcMap service to
· change the rendering of a symbol
· extract a layer to a shapefile
· geocode.
Article ID:000006093
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
