ERROR
Note: This article pertains to ArcGIS versions 8.x and 9.x. Later versions of ArcGIS may contain different functionality, as well as different names and locations for menus, commands and geoprocessing tools.
When attempting to rename a data set in ArcCatalog, this error occurs:
Failed to rename selected object(s).
This error may occur under one of the following situations:
Follow the instructions for the specific operating system in use to check and changeĀ file or folderĀ permissions.
Note: The Rename menu option is always enabled as permissions are only checked when actually executing the command. This was designed to improve the overall performance of ArcCatalog.
Article ID:000003203
Get help from ArcGIS experts
Download the Esri Support App
