ERROR
Failed to paste <feature class> The spatial references do not match
Error Message
Pasting a feature class from a geodatabase into a feature dataset returns the following message:
"Failed to paste <feature class> The spatial references do not match"
Paste failed error message
Cause
This issue occurs when different extents, resolutions, and tolerance values exist between the origin and destination feature classes.
Solution or Workaround
The latter portion of the error message, "spatial references do not match", applies to X and Y coordinates, the XY Tolerance, the XY Resolution, as well as Z or M resolutions. To ensure the data has the same properties in all these areas, use the following procedure:
  1. Load the data into the same feature dataset in the geodatabase.
  2. Create a new feature dataset with a coordinate system imported from the origin feature class.
  3. To import or copy the feature class to the newly created feature dataset, use the Feature Class To Feature Class or Feature Class To Geodatabase geoprocessing tools.
Article ID: 000012146
Software:
  • ArcMap
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
