ERROR
Failed to load resource: US_census2020.json.txt in the ArcGIS Business Analyst Enterprise Web Application
First Published: August 30, 2022
Last Published: July 15, 2024
Error Message
After updating the U.S. data pack for the year 2022, 2023 or 2024 in ArcGIS Business Analyst Enterprise, the Business Analyst (BA) web application stops responding at the splash screen while launching, and fails to load.
There is no error, but the application does not proceed past this screen (shown below) and the network traffic shows a status of 404 (not found) for US_census2020.json.txt, US_esri2023.json.txt or US_esri2024.json.txt.
splash screen
Cause
The 2022, 2023 and 2024 U.S. data updates for Business Analyst are based on the latest administrative boundaries from the 2020 Census. The BA web application at versions 11.1 and previous versions could not process the new hierarchy of Census boundaries when they were released.
The network traffic shows that it failed to load a resource. The server responded with a status of 404 (Not Found) for US_census2020.json.txt, US_esri2023.json.txt or US_esri2024.json.txt:
https://portalmachine.domain.com/webadaptor/apps/BA/esriAnalystX/services/stdGeographies/config/US_census2020.json.txt
https://portalmachine.domain.com/webadaptor/apps/BA/esriAnalystX/services/stdGeographies/config/US_esri2023.json.txt
https://portalmachine.domain.com/webadaptor/apps/BA/esriAnalystX/services/stdGeographies/config/US_esri2024.json.txt
Solution or Workaround
Download the attached US_census2020.json.txt.zip, for the 2022 data, or US_esri2023.json.txt.zip for the 2023 data, or US_esri2024.json.txt.zip for 2024 data, extract the file US_census2020.json.txt, or US_esri2023.json.txt, or US_esri2024.json.txt.zip and copy it to the Business Analyst web application files on the portal machine in the following directory:
C:\Program Files\ArcGIS\Portal\apps\BA\esriAnalystX\services\stdGeographies\config
Article ID: 000028309
Software:
  • ArcGIS Business Analyst Web App
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
