ERROR
When experiencing performance problems with a particular service, the following messages pertaining to this specific service are found in the ArcGIS Server logs:
Error: <Msg time="x" type="SEVERE" code="8003" source="servicename.MapServer" process="x" thread="x" methodName="" machine="x" user="" elapsed="">Failed to initialize server object 'servicename.MapServer': 0x80004005: Unspecified error </Msg> <Msg time="x" type="SEVERE" code="8274" source="servicename.MapServer" process="x" thread="x" methodName="" machine="x" user="" elapsed="">Failed to construct instance of service 'servicename.MapServer Unspecified error</Msg> <Msg time="x" type="SEVERE" code="9000" source="Rest" process="x" thread="x" methodName="" machine="x" user="" elapsed="">Error performing query operation Error handling service request :0x80004005 - Unspecified error</Msg>
Seeing the following severe errors in a succession in the ArcGIS Server logs indicates that a service is set to low isolation. In the ArcGIS Server documentation for tuning and configuring services, an explanation of the differences between high and low isolation are provided.
Esri recommends using high isolation. As documented in the following web help link, low isolation does increase the amount of concurrent instances supported with a single process and uses less memory on the server, but these instances are destroyed if the process experiences a crash or shutdown.
To switch a service from low isolation to high isolation in ArcGIS Server 10.5.x, follow the instructions provided below.
Note: To switch a service from low isolation to high isolation in ArcGIS for Server 10.4.x and previous versions, use the workflow below or make the change in ArcGIS Server Manager.
Note: A publisher connection also works if the service in question was published by the user.
Article ID: 000016653
Get help from ArcGIS experts
Start chatting now
