ERROR
Failed to get current license information. Unable to obtain the license info.
First Published: March 27, 2026
Last Published: March 27, 2026
Error Message
During an upgrade of ArcGIS Enterprise, the following error is returned in the logs.
Error:
When logging into the ArcGIS Portal Administrator API, the Populate License page appears.
The Populate License page
Cause
The Populate License operation applies license information from the license file used to create or upgrade the ArcGIS Enterprise portal.
Usually, this operation is necessary only if you create or upgrade portal through the Portal Administrator API, but in some cases it is required after performing an upgrade using the configuration wizard.
Solution or Workaround
In the Portal Administrator API, click Populate License to apply license information from the license file used to create or upgrade the ArcGIS Enterprise portal.
After populating the license information, ArcGIS Portal becomes accessible from both the Portal Administrator API and the Portal home page.
Article ID: 000039858
Software:
  • Portal for ArcGIS
  • ArcGIS Enterprise
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
