ERROR
Failed to execute (RasterToPolygon_1) or (RasterToPoint_1) or (RasterToPolyline_1)
Error Message
When attempting to convert a raster to a polygon or point or polyline feature class, the following error message is displayed:
"Failed to execute (RasterToPolygon_1)"
"Failed to execute (RasterToPoint_1)"
"Failed to execute (RasterToPolyline_1)"
Cause
The output shapefile is too large. An output .shp file might have been created that is approximately 2 GB in size, which is the maximum allowable size. All output is initially written to .shp before it is finally written to the desired output format.
Solution or Workaround
Some possible solutions include:
  • Reclassify the raster to create fewer unique values.
  • Resample the raster to create fewer unique values.
  • Split the raster into smaller pieces.
  • Output to a file geodatabase.
Article ID: 000006971
Software:
  • ArcMap
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
