ERROR
Failed to delete selected object(s)
Error Message
Attempting to delete a data set in ArcCatalog fails and returns the message:
"Failed to delete selected object(s)."
Cause
The data may have read-only permissions.
Solution or Workaround
Change the operating system permissions on the files you need to delete.
A. Start Windows Explorer.
B. Navigate to the shapefile
C. Select the appropriate files.
D. Right-click and select Properties.
E. Uncheck the Read-Only option.
F. Click Apply and OK.
The Delete menu option is always enabled in ArcCatalog, as file permissions are only checked when actually executing the command. This behavior is by design and improves the overall performance of ArcCatalog.
Article ID: 000003486
Software:
  • ArcMap 8 x
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
